Gratuitous Amounts of Tire
A few days ago I ordered a set of wheels and tires from a savage xl off Ebay and they are just arriving. THEST THINGS ARE HUGE!!! Here is a comparison Between them and my AKA LPR sized Cityblocks.
http://i152.photobucket.com/albums/s...0429091511.jpg THey are mostly foam and are not very heavy- but the glue job sucks hard. Couple more pics with them on the truck. http://i152.photobucket.com/albums/s...429091517a.jpg http://i152.photobucket.com/albums/s...0429091514.jpg http://i152.photobucket.com/albums/s...0429091517.jpg It is now impossible for my truck to bottom out! I have not run them but i think they might be too big for my truggy.. Ill report back with a run report on them. :) |
Hpi terra pins IIRC - I've just bought a set to - I'm going to try softening them up and use them on a super crawler
wd40 works good for softening. But just removing the foams should be enough they are very plush. |
those look cool! esp. that you say they are light too....i always wanted some big o tires for my emaxx, but my stock diffs cant handle the extra wieght.
Was going to try simple green...
They are cheap to 20.50 for 4... |
Love those tires.
if the truck will not bottom out then you are putting extra stress on your suspension components (shocks, towers, A-arms etc...). Not saying dont try it, but just realize the risks. they are cool looking!!
Make sure you stay away from 35mph+ Im sure those tires will be a handfull at speeds higher than that. :lol: I remember my imex 2.2 puller dawgs were gigantic on my pede and they would sway very easily and flip with a brushless setup.
Its kind of a hassle to change gearing just to go bashing.. id rather have a smaller tire like badlands or something. |
I'll take them,:lol: how much did your pay for them?
Edit: wait did you chew up the pinion or the tire? |
Pinion :)
I put my set from my sav on my trug as a goof. Rolled over easy and swayed alot as the tires ballooned and distorted immensely. They also hit the body when i turned. Doubt I'd call this observation "nonsense" OTOH the trug did roll right over whatever I was drving at. lol |
The crawler tops out at 2mph - I think I'll be ok...
| All times are GMT -4. The time now is 12:43 AM. |
