-   -   thinking of making another rc (https://www.rc-monster.com/forum/showthread.php?t=2053)
stampy 01.17.2006 05:59 AM
this time i wont to make a 1/10 scale 4wd truck to replace my rs4 mt when i cant find parts for it any more :( . but any way im thinking 2 stampede trannys on a custom chassie. im going to start from scratch with the trannys, i know you can make them tuff with the steel diff and aluminum idler but what about the other gear should i just go with a stock one? whats the stock one made of?
bcampbe7 01.17.2006 01:34 PM
The stock top gear is steel. You can run the steel top gear with the aluminum idler. The steel diff and aluminum idler, along with the steel top gear, will bullet-proof the Pede tranny.
For even more strength, use a 32 pitch spur and pinion.
stampy 01.17.2006 04:10 PM
steel on aluminum:eek: wont that just destroy that idler? or at leased wear it out over time
bcampbe7 01.17.2006 06:31 PM
I ran an aluminum idler with steel top gear in my Pede with my MGM120/8s brushless set-up and it held up great. The idler shows no wear. I went through diffs like no other though.:eek:
stampy 01.17.2006 07:05 PM
ok cool ill have to start getting some parts to gether and start to design this thing :) tnx bcamp
bcampbe7 01.17.2006 08:01 PM
No worries.
Post some pics when you get things going.:cool:
MetalMan 01.17.2006 09:24 PM
If you want to do a 4x4 'Pede (which is what it sounds like), I did a write-up a while back on how to do it.
http://4x4pede.freehomepage.com/
stampy 01.17.2006 09:39 PM
well im just going to use the trannys im going to make my own chassie, i think lol
