-   -   RC8TE steering.... (https://www.rc-monster.com/forum/showthread.php?t=20600)
jzemaxx 05.03.2009 12:51 AM
RC8TE steering....
Hey guys, I have a RC8TE using a JR8711 servo with a dynamite servo arm. The stocker sucked and I went with this arm for more throw, but its still does not give me any better steering radius then about 42" either way and the EPA is set to max. Are you guys using a longer servo arm then the dynamite's??? My losi 8T 2.0 using the same servo and arm turns around 34" radius. I am trying to get it to turn that tight as its costing me valuable time on the track on tight turns since I have to take them wide.
hootie7159 05.03.2009 01:50 AM
You can do the steering mod...google rc8t steering mod and it should show up..I haven't done it yet but perhaps someone who has can chime in....my rc8t turns fine ( posibly due to the fact that I'm driving a lot slower:)) but I think the mod gives the rc8t more steering throw...not sure though
jzemaxx 05.03.2009 12:11 PM
Looked online and couldn't find it. Where is this on their site?
rootar 05.03.2009 12:25 PM
are your sure your epa and exp are at max on your radio? you should have alot more throw than that... make sure your steering knuckles are travleing all the way to the stops on the C-hubs, your not getting this then you might need a longer arm....
jzemaxx 05.03.2009 12:58 PM
Yeah EPA is set to 125 both left and right. Also the knuckles do not make it all the way to the C hubs.
JerryF504 05.03.2009 02:13 PM
Did you check your d/r on your radio?
jzemaxx 05.03.2009 03:02 PM
D/r?
E-Revonut 05.03.2009 03:02 PM
dual rate
JerryF504 05.03.2009 03:33 PM
Yeah, dual rate. I'm not sure which radio you use, but if it has epa I'm sure it has a d/r adjustment too. If it got moved it would act like the epa is at less than 100%.
jzemaxx 05.03.2009 03:37 PM
Ahh forgot about that. Will check that now.
jzemaxx 05.03.2009 11:18 PM
Checked it out and got it now turning at 26". Tighter then even my Losi 8T 2.0. Much better indeed!!
nitrostarter 05.03.2009 11:56 PM
Was the dual rate the problem?
jzemaxx 05.04.2009 08:47 AM
Yes it was.
SidewaysLS4 05.04.2009 09:37 AM
Cool, you just put the RC8Te back in the running for my truggy plan, thanks
