-   -   Confustion on Mah charging. (https://www.rc-monster.com/forum/showthread.php?t=20612)
trev3813 05.03.2009 08:27 PM
I was reading over on Rcu, and someone said they have 14000mah cells, but no charger today could charge them. I thought mah didn't matter, just took more time to charge? Anyone care to elaborate? :neutral:
Finnster 05.03.2009 08:31 PM
The person that said that was an idiot. You can charge them. You may not have a charger that can do 14A charge, but I have one that does 10A. Fast enough. Insanely heavy cells tho I bet.
E-Revonut 05.03.2009 08:32 PM
They might have a hard time finding a charger to charge at 1C but even my 0606i would charge them
suicideneil 05.03.2009 08:39 PM
RCU = numpty central, after the trx forum that is...
trev3813 05.03.2009 08:39 PM
Oh, i just thought it sounded weird...
Link to thread:
http://www.rcuniverse.com/forum/m_8735279/tm.htm
BrianG 05.03.2009 10:49 PM
Yeah, not many (if any) chargers will allow you to enter 14Ah. So, you just enter the highest the charger will support. The only issue I can see is that some chargers may stop after ~1 hr as a safety net. Just restart the charge.
With the increasing capacity, voltage, and charge C rate, pretty soon we are going to need true CC/CV supplies. Good idea, but no charge profiles, safety for cell count, etc.
Finnster 05.03.2009 11:31 PM
I assumed you meant lipos..
but still.. I have (nimh) 10000mah D cells I charge on my Triton, and it does fine. Max setting is 6000mah, but even at that I set it to that, let it "trickle" charge @ 1A and it runs fine overnight. So there should be some ways around what Brian mentioned as concerns if you really wanted them.
Did I mention they are huge tho? Why would you ever even want 14000 NIMH packs?
trev3813 05.04.2009 07:45 AM
I have no clue. i Just came to the experts to get the right info. Thanks guys! :yes:
