hobby wing
i see rc monster sell's hobby wing esc.....are they any good...i am working on a raze change over....would the hobby wing esc 150amp be good.....i'm trying to stay on buget...
i know they sell that as a motor combo is that good...does rc monster sell it |
I used to use mmm but since I burnt 2 I sold it n try HW n I like it:) |
Hello!
I burn 2 Mamba Monster (V2 and V3) and I sell its after return from warranty repair. Now I run with a HobbyWing 150A and I can say that is a very good ESC! Very very bigger, but a lot stronger that a Mamba Monster! In a 1/8 conversion normally there is enought space for this ESC. I buy even a LCD programmer and it is very useful because you don't need a PC to change setup and you can upgrade ESC firmware. Regards |
Hello!
I buy it 3 weeks ago and I run approx 20 batts discharge. I run with a Feigao 7XL, 4400 5S LiPo packs or 4600 5S A123 packs. Regards |
... my first Mamba Monster burned after 2 lipo packs...
... my second Mamba Monster after only 1 lipo pack... |
Did you run your hw150A under race condition? |
I think there both good. The mmm has great service and the hw is easy to use at the track.
I ran alwas at 5S because I haven't 6S packs.
No, I'm not a racer but only a "sunday-racer" :-) But I think this ESC can support a very huge stress |
I see. By the way, dun even set the punch control to 0 or near 0. They will burn up. Reducing the timing seems to burn up these hw escs as well. I burnt up my HW80A a few battery packs after I changed the timing to setting 3. And also, I did worse things with my truck with the esc running alot hotter before i reduced the timing. It was flawless. Until I had to play with the settings. |
I hv race the HW esc with medusa motor esc runs cool, everything can be set, do not use auto lipo cutoff n do not set d punch to zero.
I use 4s to 6s it still runs cool:) |
Supertek4 do run stock timing and punch or did you change them for racing?
I take standard setup, because my Hyper ST run good in this way and I don't need any change:
Start Punch = Level 5 Timing = 15° |
Is the drive train "bullet proof"? What is the peak current of your setup? |
Weight is around 5kg with battery installed.
The drive train is the standard of the Hyper ST PRO. I don't know the exact current peak, I haven't a instrument to take a mesure when the car is running. The only thing that I can say is that my battery can give 4,4*35=154A in burst mode |
| All times are GMT -4. The time now is 03:18 AM. |
