Tekno Neu melted wires
Well I converted my revo to brushless some months ago and am running a finned 1515 1.5D 2700kv Tekno RC Neu along with an MMM on 4S.
I have probably had something like 20-30 packs in it with temps well within range. Last time I ran was in my backyard to make my dogs run a bit, so I was pushing it pretty hard cause I didn't want my 3 rottweilers to get ahold of my truck :lol: Everything was fine. Today I ran like half a pack (2S2P Losi hardcase 5000mAh) in it cause I forgot to fully charge it, LVC pops on. And when I pop the body off I notice that my packs are really warmer than usual, nothing crazy tho. BUT my motor wires melted, all three of them on about 4-5cm!!! Motor was burning hot aswell. MMM didn't even have its fan on, was warm as usual... Any idea what happened? Will I be fine if I just put some heatshrink back on the wires? thx for any help |
Probably a broken motor winding. Once one breaks (Even just a strand or 2 in one winding) the motor starts to get hot...fast. SOunds like that motor is done for. Send it in to Neu and see what they say.
Either a motor winding, or possibly your gear mesh slipped and tighten up causing problems as well...
sounds sorta like the same thing that happened to my tekno 1515 1y/f. it was temping fine after running two sets of 4s though it. take it out a few weeks later and I don't even finish off one set and the motor is cooking hot, like 180deg+
I take it home, hoping I didn't demag it. pulled the endbell off and pulled the rotor, which from the force needed to pull it out, I doubt it demag'd. Anyway further inspection revealed some blackening around the end of the heat shrink at the end of one of the phases. I cut it back a little and it looks like 1 or two of the wires shorted out. http://members.shaw.ca/chris.hung/RC.../neudamage.jpg http://members.shaw.ca/chris.hung/RC...neudamage2.jpg |
Thanks for the pics and the info guys.
Sending back my Neu for warranty is kind of an issue for me since I am in the south pacific... I'll try to pop out my end bell to check it out. |
Thanks Tekno, I'll be sure to mail it to Neu when I get a chance.
| All times are GMT -4. The time now is 02:52 AM. |
