endbell covers for hand wound neus
i'm running an 1/8 onroad conversion and am about to drop a 1515 1Y in it. i've got it geared fairly high, and i usually cover the endbells but for this one, i was thinking maybe i should just leave it open for added cooling.
is this a bad idea? is it ok to run them open? am i posing any risks to the motor? any advise is appreciated. |
Just that dirt/dust can get into the motor. And since there is little clearance between the coils and rotor, you could scratch them up.
Well, if a big enough rock gets in there, it could jam the rotor and/or tear the coils apart. That's probably a worst-case scenario, but it's a possibility.
does mike still make the front cover? (the one that goes where the wires are coming out)
| All times are GMT -4. The time now is 05:11 PM. |
