hi
does anybody have a heat sink that will fit the stampede motor
Which stampede motor do you have? the Titan 12T or the older stinger or other 540 sized can?
hi
Get some thermal paste as well.... if that doesn't cut it get a fanned one.
exactly how much are you trying to lower your temps. |
What voltage are you running that system on too? Gearing will affect temps too- whats your full setup at present?
hi
48spur? Do you mean 48 pitch???
If you're running a 48T spur, thats you reason for heat!!! I'd try 16-18/83 gearing with that motor. |
Are you really running a 48T spur? or is it a 48 pitch spur?
48p, i think he has the 76t spur.
Read my question again- what voltage are you running? 2s or 3s, or how many nimh cells?
7 cell trinity 5000mah
| All times are GMT -4. The time now is 08:39 PM. |
