D8 Measurements
Hey all,
Is there any chance that someone could measure the distance between the front of the centre diff mount and the steering assembly? (I want to use Mike's mount to fit the motor at the front so need to know how much room there would be for it, so if you could 'imagine' where the motor mount would be and measure from that?). Also the distance between the middle of the centre diff mount, and the rear bulkhead (i.e how much room is on the chassis between the rear bulkhead up to the middle of the centre diff). And finally, how much room is there between the edge of the chassis and the rear centre driveshaft (with appropriate clearance). Thanks! |
| All times are GMT -4. The time now is 08:06 AM. |
