Motor plate for MLST2
What motormount shall I use on my MLST2 with a Mamba 6800 motor.
Will the GPM alu work? |
that motor is a little small for that truck. hobbycity has some decent 370 sized motors that should work. get a l or xl length motor and shoot for 2500-4000kv. those 370 sized motors will have more kick, will run cooler, but will draw about the same amps with lower motor speed than the mamba 6800kv motor.
Thanks for the info. Only problem is that I have allready bought the motor ;o)
But I will try to mount it and see what happens. |
Make sure to try a very low gearing first.
| All times are GMT -4. The time now is 05:55 PM. |
