need help with measuring for center shafts
I need a set of center shafts for my Mutant Maxx build. But I dont know how to measure for them. Do I measure end to end of the shaft or center to center of cross pins. Any help would be greatly appreciated
i would use metric measurement from pin to pin
Now do I measure from center of each cup? I need to know basically when I buy a 120mm dogbone are the cross pins 120mm apart or is the dogbone end to end 120mm
depends on manufacturer
| All times are GMT -4. The time now is 06:05 AM. |
