I Think I Broke My System!!!
i did a backflip and had a bad landing. Than it stopped, i took ti home and lifted it up. when i pull on thorttle, it coggs ALOT. Im on 1/3rd full throttle and it still coggs... I tempted the motor at 180... It was only 16 cells. I was tempted.... Plz tell my my ewsc is fine, and that its just hte motor!
You may have messed up the esc. Did it land on the esc or just jar it real hard? Make sure all your connections are still tight.
Nbcazn. Did you try the flip without the body
You might of bent a CVD or something, or broke a tooth on spur? Can relate to a "cogging" effect.
check your batteries. might have a loose battery bar or you might have knocked something loose in the esc like a cap or resistor or something.
I tookt he motor out, and it COGGS like crayz. Its not in the revo or anythign either...
did you check the batteries?
did you check your wires. batteries. and stuff
You probably wont find anyone to trade with you this time, buddy. Though I'm not sure.
batts are fine, so are wires. OH shoot...i smell something on the esc. It smells liek my 959 when im charging batts. DONT TELL ME IT FRIED? its temp was only 130!!!
temps not everything. you could have had something shooken loose or something.
inside the esc?
It doesn't sound too good..
phil |
yes, inside the esc. i know that metalman has had a similar problem i think. he opened it up and had a missing resistor and a broken chip fet i think.
lol, how much woudl ti cost to send it to BK and have them fix it? I dont wanna messs with this stuff
| All times are GMT -4. The time now is 03:26 AM. |
