what is the best brushless motor and esc
i got a novak hv . was all right in standed emax but not that good in gorilla maxx .not much chop . i think there is something wrong with it. was thinking of a 10L with a Schulze 18.97 . want to get a good setup to race something with a bit of punch . can any one tel me the best setup motor and esc
Me personally I like the xl motors. It seems to do better than the L motors. Just my opinion. You going to keep running the 14 cells.
Re: what is the best brushless motor and esc
yea, xl motor with 9920 is the way to go.
The ultimate setup would be a Lehner 1940, although a Feigao/Wanderer XL with a 9920 should do the trick for less. All of this can be found on the store here.
How many cells are you planning on running? |
going to run 14 cell . what size xl is best
14 cells up
What kind of run time your shotting for? A 9xl is a good motor for 14 or 18 cells. Has good run time and power. The 8xl has a little short run time and faster speed. 7xl has good power and low runtime but good speed.
for 14 cells and up i would go with the 9xl.
whats a good brand in xl motors
Lehner 1940 what would be the best turn 6,8,10 and hi amp
no sure about which lehner but as for xl's i would go with the wanderer. it has better bearings than the feigao and has 5.5mm connectors already soldered on.
| All times are GMT -4. The time now is 12:27 PM. |
