more efficient?
I am currently running a 1512 3d in my losi 8 on 4s which seems to be perfect for me, but due to the low rpm, am I loosing efficiency? Would a 1512 2.5d run cooler and more efficient geared at the same speed (38mph)?
FYI, I ran a 1509 2y this weeked for 2 10min runs for practice, the 2 5 min qualifiers and on the 3rd 5 min qualifier it went up in smoke. It felt really good but I guess it was too much for the motor and it was running pretty hot from the get go. I had to put the 1512 3d back in for the main. |
Too low of an rpm may cause a little cogging at startup if anything. But efficiency should be fine. If startup and top speed is fine then I'd leave it as-is.
Not really. Your setup requires X amount of power to run like you want. Whether you use what you have or use a different motor geared for the same speed doesn't matter. The output is the same.
Thanks Brian, and BTW your gearing page rocks! |
| All times are GMT -4. The time now is 01:36 AM. |
