SOB! Did I ruin my MMM Castle?
Ok, I feel like a complete and utter nimrod today after I got back from my bash session. I was cleaning my Flux when I took off the RX cover and I about fainted when I saw. I had pinched the wiring from the ESC between the chassis and the cover. :gasp: Luckily, it looks like it only went through the outer coating and my Flux drove fine with no issues that I could tell and I was able to connect to my Castle Creations link with no issues, but i'm still worried that I might have ruined my expensive ESC as a result of my stupidity :cry:
Any suggestions Castle or am I farked? I put some electric tape over it and ran software updates on the CC link and doesn't seem to have a problem, but im still concerned.... http://i100.photobucket.com/albums/m...ux/screwup.jpg http://i100.photobucket.com/albums/m...x/screwup2.jpg |
I would put a little hot glue on the wire to protect the strands. And don't do that again!
Think your over reacting a bit. You can do what linc said or take a small portion of the wire out and resolder it with heatshrink and everything.
even if you did ruin the wire's, its an easy fix
castle will fix it for cheep if you can't |
Pull the wires apart from each other and fold a bit of electrical tape around the individual damaged areas, then wrap more tape (or heatshrink) around the whole section of cable.
| All times are GMT -4. The time now is 06:13 AM. |
