Cracked lipo case
is this bad ? the lipo itself look ok, it has a very small dent inm it there.more of a mark.
http://i62.photobucket.com/albums/h9...edlipocase.jpg |
Run it! If it doesn't work fir you Thursday I'll bring a 5s setup for you to run
it should work fine, there no rip or puncture.
Put some hot glue over it and run it. Just a cracked piece of plastic!
i took an old associated battery cup and cut it down some then shoe goo'd it onto the pack.
cut it and put some sho goo on it http://i62.photobucket.com/albums/h9...lipofix003.jpg then placed on the end of the pack http://i62.photobucket.com/albums/h9...lipofix004.jpg |
Was that a TP pack?
just for the sake of knowing, how does one tell if a lipo pack in a hard case puffs or swells ?
thanks, i was wondering how one would tell,i didnt know if the case would separate or not. i was looking through your repair thread and didnt find any puffed lipo packs in a hard case.i was wondering what they looked like. |
Yeah you can see the plastic bulging a bit. The worst thing I have seen happen to a lipo was a hard case orion 4800 that was accidentally charged on a nimh setting . The cases separated without being damaged and the pack ended up being about 4 inches tall. Was noticed just in time, so no smoke or fire.
thats always a plus. |
| All times are GMT -4. The time now is 09:27 AM. |
