-   -   HW 150a baseline settings (https://www.rc-monster.com/forum/showthread.php?t=21032)
truggyracer1 05.22.2009 05:58 PM
ok....big race tomorrow i have the 150a HW esc in my truggy and i'm looking for a base line setting the specs are medusa 2300kv motor 13t pinion,46 tooth spur,43/10 gearing and 2 2s 7.4 5000mah lipos i have the program card so i can easily set the ESC just need a good baseline! i hear that the medusas like to be set at 15 degrees timing i was going to set the lipo cutoff at 3.2 volts as far as drag brake and brakes and what not need suggestions......thanks in advance!!!
superek4 05.23.2009 11:25 AM
I set my punch at 4, drag brake 0, brakes 50%. batt setting according to d cells not auto. That shld b all good luck
_paralyzed_ 05.23.2009 04:24 PM
i suggest going out and test driving your setup before even thinking about racing
