Help me select a setup
Well i finally plan on converting my savage in the next few weeks.My options are:
Option 1 : Feigao (8,9,10,11,12 XL?) with ezrun 150a esc,with zippy 6s 5000mah 25c. Option 2: CC2200kv with ezrun 150a esc, and zippy 4s 5000mah 25c. With option i am saving about $40,and it should be faster. Now i am wondering how reliable the Feigao motor will be on 6s?Will it get to hot?Which size feigao motor should i pick and with what gearing?(savage flux tranny,with 47t spur) Also on 6s i may need to adjust the punch,and i am wondering if the ezrun 150a esc still has the problem of failing when the punch/timing is adjusted?If they do have the problem still,then i may have to go for the mmm. |
Id go with the 2200. way more powerful then a feigao, Much more reliable and cooler temps.
MMM 2200 is your best bet. |
| All times are GMT -4. The time now is 06:01 PM. |
