-   -   Glitching at high speed (https://www.rc-monster.com/forum/showthread.php?t=2115)
nitrostarter 01.22.2006 11:02 PM
My Maxx has a 18120/9L in. It seems to be very glitchy. I dont know if its my radio signal or not. It happens with when the truck is going at a good speed and I let off the throtle. It glitches to lock up the wheels for an instant. This has caused the bottom output gear of my tranny to go out twice. Is there something I should do?
squeeforever 01.22.2006 11:36 PM
have you tried to reprogram the controller?
$w!ft 01.23.2006 11:11 AM
Mine does exactly the same!
I do a high speed pass, then let of the throttle and the tires lock completely for a tiny instant. Its kinda weird. Runnin 18120 and 1930 motor.
I think its the esc program.
nitrostarter 01.23.2006 02:22 PM
At first I thought it was my reciever was going out and sending bad signals because I was having trouble with my steering servo also. I put a new radio system on and it does the same except the steering servo works fine.
Leave me to question the ESC. I wonder if there's anything we can do about it?
$w!ft 01.23.2006 02:26 PM
Well if you look in my other post my rx pack drained in about 15 min which is kinda weird for a 1100 mah 6v. MAybe this is related.
coolhandcountry 01.23.2006 08:41 PM
Some one had a problem like this and had some metal rubbing. Make sure you don't have this problem.
nitrostarter 01.24.2006 12:42 AM
My stock reciever went out and I had this problem. So I changed radio systems and on the first run I wheelied and skidded on the antenna and cut it in half. So the antenna is solder in half and wrapped around my Dace wingmount shock tower. Think there's a problem there?
