6s on M Monster
I'm converting a losi 8ight T 2.0 and I plan on running 6s. My question is, does the bec have to work harder with higher voltages, will I have a higher likely hood of damaging the esc on higher voltage. Would it help if I run a bec? I already have the CC bec
Actually, most switching BECs (which is what the MMM has) tend to work more efficiently with higher voltage because of the reduced current needed. And, there is less chance in saturating the main switching coil with lower currents.
However, a linear BEC (which is what the MM has) gets less and less efficient as input voltage climbs. This type should only be used with 2s lipo max, otherwise, disable it (remove the red wire) and use an external switching BEC. BTW: Welcome to the forums! |
Since I've sold all my nitro stuff, I still have a nice jr9100s HV servo laying around, this is the all aluminum case with .06 speed and 230oz of torque. I was planning to use it but with only 6 volts coming from the bec it's specs drop down to the normal 9100 180/.06. If I install the CCbec so I can boost the voltage going to the servo, will there be any pros or cons using it instead of the built in bec on the monster? If I do go with the cc bec, is the installation the same as with the MM, just remove the middle wire comming from the esc?
The external CC BEC most likely has more current rating, and is voltage programmable, so it should have no trouble powering the servo. The downside is the extra wiring required. And yes, just remove the red wire from the ESC.
Keep in mind that removing the red wire from the ESC throttle cable will make programming the ESC more difficult. If the red wire is permanently removed, the only way to program the ESC would be to power it up with at least 2s lipo/6 cells while the Castle Link is hooked up. Options to get around this limitation: - Make it so the red wire can be re-inserted easily. - Use a short servo extension with the red wire removed. This would leave the ESC cable unmodified. |
I have been told by Pat that the higher voltages do work the DC-DC unit harder because of the higher switching rates.
I say don't give it a worry. |
You would put the servo load on the CC BEC, and I can't comment what is better. I would not use an external BEC personally, as my MMM have been running fine.
Thanks for that info. Makes sense. So, the FETs work harder because of the higher partial currents, but does the coil or diode (assuming it's not running into saturation) work any harder? |
So even though they work harder, efficiency increases? Does this bump up output as the voltage increases, or does it decrease from the possibility of extra heat?
When testing different BECs, it seems the coil is the hottest part at any load and input voltage, so that makes sense. The only BEC I've ever tested where heat is more distributed is the Western Robotics HV; but that uses a very large/robust coil so it probably has enough mass to absorb it better.
| All times are GMT -4. The time now is 04:00 PM. |
