HPI Baja 5B with Zenoah ESP 27.2 motor
This baja is very fast and runs great! It has the ESP 27.2 Zenoah in it with a fresh piston and ring in. Only about half a gallon through it with the new internals. The only reason I rebuilt it was I had to replace the head gasket due to it being blown out with a copper gasket. So while I had it opened up I did the piston and ring.
So 27.2 ESP Zenoah with billet aluminum flywheel cover, DDM chrome side Dominator pipe, It has all the Turtle stuff in the rear end. Front Ramtech shock brace, Rear Turtle brace, steering servo has metal gears in it. There are some more things just cannot remember off hand. This will come with all the extra parts I have included in the picture. Also will come with a extra Walbro 813 carb. I will also include some paddles on wheels that are about half worn, and some dirtbusters on wheels that only have about 2 light runs on them. The bad: Chassis on the bottom is pretty scratched up due to running it in a gravel pit. Also the spark plug wire on top has a hole on it, it works fine but I would replace it. also the top fuel line broke off at the plastic fuel inlet on the carb. No biggie, you could just take the one off the extra included 813 carb and replace it. 4 screws on top and it is off. No radio or RX is included, will only ship in U.S. Will ship only in U.S no trades http://i39.photobucket.com/albums/e1...6/100_2930.jpg http://i39.photobucket.com/albums/e1...6/100_2931.jpg http://i39.photobucket.com/albums/e1...6/100_2932.jpg Included: http://i39.photobucket.com/albums/e1...6/100_3441.jpg http://i39.photobucket.com/albums/e1...6/100_3444.jpg http://i39.photobucket.com/albums/e1...6/100_3442.jpg |
| All times are GMT -4. The time now is 01:12 PM. |
