Kyosho diff question
I hope to be in the right sectio of the forum...
I need to lock fully the differential of a kyosho inferno sport 7.5, I noticed there is a set screwon each diff carrier, closing this screw lock the diff. nowthe question is: if I run my car drifting with all diff lock throught this screws do I brake the diff??? or I can just close this screw to lock for drifting and then untight to loose the diff and go off road? thanks |
that screw is not for locking the diff- its for draining and filling the diff with fluid..
Use only diff lock. |
| All times are GMT -4. The time now is 08:30 PM. |
