-   -   Hyperion Duo charger (https://www.rc-monster.com/forum/showthread.php?t=21211)
captain harlock 05.29.2009 03:57 PM
Hey guys!
I was wondering whether the Hyperion Duo can charge two packs at a time or not.
If I have two 3s 3700mah lipos and I want to charge both at once, will that charger enable me to do it?
I need to confirm this befor purchase.
Cordially,
Alawi :)
nitrostarter 05.29.2009 04:00 PM
Yes sir. Thats what the Duo was designed for, 180watt max output on both sides, Just make sure that you get a big enough powersupply if you plan to charge high capacity high voltage packs.
captain harlock 05.29.2009 04:54 PM
Will a 25v, 25amp power supply be enough?
Also, if you have this thing, how much do you like it?
Thanks, Nitro!
Arct1k 05.29.2009 04:59 PM
Hyperion chargers are very simple to use and excellent quality
TexasSP 05.29.2009 10:32 PM
Ditto what Arct1k said.
BrianG 05.29.2009 10:53 PM
Thanks, Nitro!
lol, I should hope so! 25v @ 25A is 625w. Even figuring a little wiggle-room for supply longevity (15%) and charger efficiency (~80%), that still leaves you with 425W. That's enough to charge a 6s lipo at almost 17A! But the charger can't do that. You'd have to get close to maxing that charger out (250w per channel IIRC) to overload that PS.
kulangflow 05.30.2009 09:26 AM
I love my Duo! You just can't go wrong with it.
YogyBrushless 05.30.2009 02:56 PM
i have it and its great ! and yes it does charge two batteries at the same time
