-   -   Awesome electric go karts (https://www.rc-monster.com/forum/showthread.php?t=21239)
Krawlin 05.30.2009 07:35 PM
Got two videos of electric go karts you guys might like.
First up is a brushless kart, has 3 Turnigy outrunners and a centrifugal clutch and 12S10P LiPo -
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/vwODx028_Jw&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/vwODx028_Jw&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
When they really nail the throttle it spins the tires while rolling, talk about torque!
Second is a kart with 8 12 Volt deep cycle batteries and a 48 Volt 1000 Amp PWM motor controller, not sure on the motor -
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/-xitMWUfeLk&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/-xitMWUfeLk&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
That one is pretty cool too, but I wish they did some kind of speed run in the video. Seems to have alot of torque though.
I wonder how much it would cost to convert a kart, like just a rough average. I have a racing kart like the one in the first video that I used to race when I was in the 5th grade, got out of kart racing and haven't touched it since, might be a cool project to convert it.
nieles 05.30.2009 07:38 PM
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/bERjkSTYOdU&hl=nl&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/bERjkSTYOdU&hl=nl&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
brushlessboy16 05.30.2009 07:59 PM
in the first vid- that clutch is not happy at all.....
thats it smoking not the tires.
Andrew32 05.30.2009 08:12 PM
+1!!! poor clutch never had a chance lol
Second vid...AWESOME!!!!
lincpimp 05.30.2009 08:46 PM
It needs alot more clutch, or much lighter springs, or something...
brushlessboy16 05.30.2009 08:56 PM
Or... just dont use a clutch.
A RC Dude 05.30.2009 10:32 PM
+1 on that
Overdriven 05.30.2009 10:36 PM
The clutch was a good idea in theory, as it'll eliminate cogging and make it easier on the motors to get the kart moving from a stop so they should heat up less. So to be able to gear for over 30mph and move 200+lbs, I think it was a good idea, especially if you were going to use only 2 motors. The clutch they used however looks like one a cheap 3-5hp gokart would use so an upgrade is definitely in order.
Takedown 05.31.2009 04:41 PM
On somthing that heavy your going to need a clutch setup no doubt. Sensorless + 200lbs + clutch= smoother running and it will be much easier on the elec's. Plus you wont have to push start. I could maybe understand not using a clutch on a monster single sensorless motor but with 3 motors on one shaft you have to give them some leway.
What's_nitro? 05.31.2009 08:37 PM
If they get a heavier duty clutch they'll be GTG. I would suggest one pulled from a large chainsaw, like 80cc+ large. :yes:
