Esc heating up ?
I played today with my crt.5 and all goes fine now back from playing again and the esc heating up for nothing ... the motor is cool and the batteries also but the esc can goes up to 200f + into few minutes maybe less...
back from trying a external bec and the same :neutral:
we need more information dude. this doesnt tell us squat. for all we know you could be running a hw 18a, neu 1527 and AA's
jammin crt.5 1/12 truggy
1/10 mamba max esc feigao 8xl 3s lipo 5000mah 25c 17/46 gearing top speed around 35mph ... all worked perfectly fews days ago and sudently the esc heating up for nothing ... |
jespere que ta pas les gros tire que ta montré a carl...si oui pose pas de question au sujet des temperature....:whistle:
heh oui j'ai c gros tires la j'ai rouler pendant 2 jours pis aucun probleme de température mais la je comprend pas... p-t le moteur qui est foutu ?
Oh the joys of canadians eh. :lol:
Can someone fill us in? Were in Uh'mericah :) |
loll yes could it be your motor...FEIGAO=CRAP...i sold you a neu few month ago yer rendu ou ste moteur la?????..enleve les tires cer dla boullshit:yes:
sorry brushlessboy16 but jason had some really big tire un is crt and and cheap motor=the present result:whistle: |
le Neu est dans mon kyosho st-r 1/8 truggy :yes:
ok ..good...bon first...baisse ton timing a lowest...punch at 60% combien de kv ton moteur..... ya tu dejas overeated?
do you have the latest soft??? |
anyway...your motor draw to much amps for the cell capacity....and the esc is not able to drive the motor ..well i think...
le timing est low , start power low , punch control 70% j'ai essayer la version 1.20 pis 1.21 du firmware ... j'ai jouer avec depuis je l'ai avec c gros tires la pis rien chauffait c jusque que cette apres midi ca commencer a chauffer
combien de fareineith i pogne????what temp exactly...if you can hold your finger on it...its ok next run check with a temps gun:whip:
jvient dessayer avec les tires on-road qui a venu avec pis le esc monte a 200f + aussi :)
chavait que sté pas a cause des gros tires ;) pis le moteur rien a dire ca chauffe pas ... juste le esc ... |
I resent the comment... :no: What do you expect, they are French! :lol: |
| All times are GMT -4. The time now is 12:45 PM. |
