-   -   Best motor length / kv for 8T (https://www.rc-monster.com/forum/showthread.php?t=21353)
medusa'd maxx 06.04.2009 06:45 AM
I am doing a brushless conversion on an 8t 1.0 and I'm
going to use a medusa I use a 36 80 1600kv in my Emaxx on 6s which runs fine but for some reason seems toheat up my ESC - motor stays about 150F
ESC (MMM V3) has hit 170F
Im looking for a cool setup on 4 or 5 cells I'll be using a MMM again and I'm looking at doing some racing as well as some fast grass running (short to med length)
should I stick with the 80mm can? Ive been thinking 5S with a 2200 or 1600
any people out there tried this set up
Arct1k 06.04.2009 08:31 AM
70mm should be fine 80mm would give you some extra flexibilty on gearing.
I would go with the 2000 as a compromise or the 80/1600 and gear up
medusa'd maxx 06.04.2009 11:31 PM
15% off
2000kv 36 80mm on its way - got to love 15% off:yipi:
now all I need is a decent sized batt zippys are thin on the ground at the moment anyone got a similar priced alternative - Im after 5s 5000mah 25c or better
