-   -   Could a CC Sidewinder handle this motor? (https://www.rc-monster.com/forum/showthread.php?t=21398)
fastbaja5b 06.06.2009 09:54 AM
Looking at an ESC for my Slash, got this cheapy motor for now:
http://www.hobbycity.com/hobbycity/s...idProduct=6530
And will put in an identical spec Medusa when funds permit.
On 2s/ 3s would the Sidewinder handle it or should I go the Hobbywing 80A
BL_RV0 06.06.2009 02:00 PM
It would do ok on 2s, but you may need a ext. bec for 3s
Metallover 06.06.2009 03:04 PM
With your motor you could get a $5 external bec while you're at hobbycity.
alangsam 06.06.2009 03:23 PM
sidewinder is fine on 3S
lincpimp 06.06.2009 03:54 PM
While the sidewinder will do fine with a bec on 3s, the hw80 is a more versatile esc and can do 4s with need of an external bec. Plus the price is very close. I do have a few sidewinders and they are great escs, and I have not tried the hw80, but it has had favorable reviews and seems to be a bit underrated on its amp handling ability.
alangsam 06.06.2009 07:32 PM
fundamental difference. when the hobby wing smokes you throw it in the trash. when the sidewinder smokes you send it to castle.
What's_nitro? 06.06.2009 10:28 PM
The real question is- can that motor handle a Sidewinder? The SW is rated for ~70 continuous at 3s lipo. If the HS specs are right (?) then the SW will have NO trouble running that motor. An external BEC is ALWAYS a good idea because it takes the load off of the ESC.
