Anybody have an easy way to convert emaxx to truggy?
Besides Promod, has anybody else replaced the tranny with a center diff yet? Anybody run into problems with having no slipper? Any kits available yet? I'm thinking of going to center diff only also, but would like to find a center diff that was actually ball diff to allow for slight slippage to protect the drivetrain a little.
In an application like that, I dont think you would be able to set up a ball diff to slip without it melting itself.
Candyman has done a conversion, it's easier than people think, but you need a dremel at hand.
Coolhand_country has done one of his trucks with a center diff. Candymans is a slipper clutch and i'm not sure if Promod is a diff or a slipper
I'm doing a center diff conversion myself as we speak.(well planning anyway).
I got a nice idea of how to mount a 2 speed center diff w/ strobe slipper, but the thing is it will be way undergeared.(the smallest gear for the 2 speed is something like 48 tooth, the smallest on the strobe slipper is 51 t. Will need either a massive pinion or do without the slipper) If your not into jumping much you don't need a slipper. I'm going center diff only, no slipper, I do jump, but if you take the throttle off before you land there isn't a problem. |
| All times are GMT -4. The time now is 09:00 AM. |
