Supermaxx 6spyder ultralite diff
Hello there,
Mike and UE are both out of stock of the 6 spyders and 8 Sspyders does any one know when they will be comming back into stock? or know anywhere with a set instock? Same goes for the supermaxx servo saver Thanks :) |
I have Hot Bodies buggy and truggy diffs in stock(work just as well as the UE diffs-the truggy diffs offer more reduction as well). FYI. Your guess is as good as mine on the servo savers, though.
What is the reduction on those truggy diffs, Mike?
10/43 vs 13/43 of the buggy diffs. :) Almost 25% more reduction(perfect for a center diff driven truck)
I not entirely sure what you mean,
So are they as Strong as the UE diffs? Will the fit a stock style E-Maxx bulkhead. Do they come with diff cases like the UE's ? Thanks |
The HB diff do not include cases, but are otherwise similar in strength and size to the UE diffs. The HB diffs would need hybrid bulkheads to work in an e-maxx( or UE cases, which aren't currently available). The Hybrid bulks are a great upgrade, too.
The Hotbodies diffs are better than the UE 6 spiders. the UE's uses cheap pot-metall gears, the HB's are unbelievable tough. very tough gears inside, and it uses hard chromed crosspins as well.
My tip; get the HB's. they are helical cut as well, (more helical than the UE's) so they run more quite as well. |
So something like an integy case wouldnt work?
no, they are crap, compared to the HB/Kyosho/Ofna cups. You really don't need aluminum cups, your better of with the tough plastic of the earlier named brands.
I would look at some ofna buggy diffs to. I don't know who has them beside mike or ebay. I got some ofna from mike that are awesome.
How much will a pair of the HB diffs cost me compared to the 8 spyder diffs? And does any of you have some pics of them to post?
The cost is about the same. The diffs look about the same, too. :)
Coolhand - The "ofna" diffs you got from me are the same as the UE 8 spyder diffs(or should I say the UE 8 spyder diffs are actually made by ofna). I like the HB truggy diffs myself. |
Towerhobbies sells both HB and Ofna diffs, though I'm not sure if they are the same 7.5. These are ofna super torsen diffs 9.5, and they are super expensive, too, so whats the difference?!! There is an optional and standard HotBodies diffs, too.
3 Attachment(s)
Here's some pics:) :
I will have to get me a pair of those truggy diffs!
They will come with input pinion, but without bearings, right? I guess all I need now is a bulkless conversion for the Revo. |
| All times are GMT -4. The time now is 07:57 AM. |
