Ben's Electric Bike.
Well Here it is, starting the project off with a 20in Redline Bmx Bike.. All steel frame etc. Its a nice bike to begin with, steel frame and some decent wheels.
To power it I have one of these big ass brushed electric motors that i have laying around- and a 16:1 gear reduction box. Also picked up some 35 chain and sprokets for drive... BrianG- your gearing calculator is a life saver.. have it spec'd out at 22mph on 6s lipo. with low gearing and lots of reduction it should keep amp draw relatively low. Just a project to get me from point A to point B being as lazy as possible. Planning on making a steel subframe/ motor mount and weld it to the existing frame. Pictures will be up later today. |
1 Attachment(s)
Here is the bike..
Is there any way to directly control a speed controller with something like a potentiometer? I can get a twist grip for an electric scooter if there is any way make it work. if not, does anyone have or know how to make a cheap servo tester? |
"Bad lutach first"
You know what's coming for you Ben :rofl:. No Ben, don't do it. Steel is much harder then aluminum and if it bends, it'll be much harder to bend it back to it's original place :lol:. So have you fixed you mount yet :oops:. "Good lutach second" There are some very intelligent guys in the forum who has vast experience with such a project. I'm sure they'll be here guiding you. |
You can use a servo tester for controlling the speed controller if you have an rc type controller.
Metalman had a link to a twist grip control that would run a rc type esc. Can't remember where he had it though.
I was in Academy Sports this past Saturday and stumbled upon the battery powered bicycles for him and her. They use a brushed motor like the electrics scooters do. They just basically adapted the scooter setup onto a bicycle.
Thanks luciano, but i have no problems with steel, it will be built with braces etc to stop from bending.. Quote:
Yea, but the speed controllers they use are not as efficient or powerful as any Rc controllers. Im probably gonna use my MMM for the moment in this one. Quote:
THanks for the info guys. Now, since i want to retain the stock pedal system- would i be able to set a slight drag brake on the MMM and use the regenerative abilities of the speed control to recharge the batteries? I dont know how much power the regen braking actually saves.. |
I can't wait to read the plea to castle to replace your MMM when you fry it - lol
"my e-bike shouldn't void the warranty, I only ran it on 6s....":lol:
i cant wait to see this!
velosolex
hey,
look at this: http://motorbike-search-engine.co.uk...solex_5000.jpg put the motor and the electronics to the front; batteries into the center of the frame. you will need a big outrunner, at hobbyking they have som 8cm monsters with about 250 r/min. you could design a mount, where the motor gets - by pulling a lever - contact to the tire. so when you don't want to use the motor, no problem when going downhill very fast. they have now designed a e-velosolex: http://s3b.directupload.net/images/0...p/kyrfh4qp.jpg anyways, cool idea, btw!!!! just recently I saw a high-end e-bike on tv, fast like a motorbike. brushless rulez :lol: |
I'm not sure if they have this, but it would be neat to have a motor setup so that the more force you put on the pedals, the more motor assist there is. And you could set the relative assist amount. Wouldn't need a manual throttle this way.
hmm if you were to have a pressure sensitive potentiometer, on the pedal and have a proportional value applied to the speed controller.
Does anyone know if I can run two seperate speed control in series to a motor- like 4s on each for 8s to the motor... its brushed. |
I'd say no as the FETS would be out of phase between the ESC's.
| All times are GMT -4. The time now is 03:22 PM. |
