-   -   kyosho mp 777 wc interchageable parts (https://www.rc-monster.com/forum/showthread.php?t=21558)
steveo 06.13.2009 02:25 AM
who can tell me if the parts on all the latest and past kyosho buggys fit they all look pretty much the same is there a difference, new to buggys and there are many different variations of the inferno buggy series
cmcclive 06.15.2009 09:34 AM
Basics:
(this is from memory)
SP2 and WC are almost completely interchangable (aka WC parts will fit a SP2 SP2 parts will fit a WC, but some of the WC parts might be "better")
for the drivetrain:
-The Universal swing shafts from a SP2 or WC can go in any buggy (the older buggies didn't have one piece parts, but could go into a SP2 or WC).
-The SP2/WC has a longer chassis then previous versions. The center CVDs are the same length front/rear on the SP2/WC, for the previous versions they were not (make sure the buy these as either SP2/WC or SP1/777/7.5 depending on what you have).
-Diffs are interchangable
-Mud gaurds are interchangable
-SP2/WC have more adjustable shock towers (more holes, for more setup options) but you could run an older tower on a newer buggy, or vice versa (I think).
-Suspension and shocks should be interchangable (although WC has the big bore shocks, which are better).
To be honest I am not sure what the differences between all of the models, I did just do a quick search and found that the 7.5RTR wasn't very good (cheaper parts, sorta like how the RTRs from Losi use much lower quality parts then the kits).
My suggestion is if you want to go kyosho (expensive parts that are hard to find) stick with the SP2 or WC, personally I run the SP2 (with random modifications, but not to WC spec) and I don't have any problems with it, other then part availablity.
steveo 06.15.2009 06:28 PM
dude thanks, thats what i wanted to hear, alot of stuff i see either says sp1 or sp2 not wc and it through me off
do you nave some pics of your kyosho and how does it handle
cmcclive 06.15.2009 07:44 PM
I only have pics from last year, I haven't taken new pics yet (I have made noticable changes). I will update my old thread soon (hopefully).
As to handling: I have no complaints, I am not the best driver, but it works for me. The buggy (well SP2 version) is a bit heavier then some of the others out there, but it isn't so bad as long as you have the proper motor/battery/gearing.
Do a search for MP777s or Mp7.5s there are a few build threads around you could look over.
