-   -   Kyosho FINISH RESULT (https://www.rc-monster.com/forum/showthread.php?t=21562)
jalodo56 06.13.2009 05:19 AM
I have just do my finish result of my kyosho, now it is how I want...... It run with neu 1515 3d on 6s 5000mha, Can I run 30min?. I want that it run very cool, because in Spain the temps in summer are high, are about 110f or higher.
http://i477.photobucket.com/albums/r...o/DSCF4048.jpg
BL_RV0 06.13.2009 01:07 PM
Yes that setup will run cool. Very nice buggy!
jalodo56 06.13.2009 03:00 PM
Hello I have just run the buggy with 100ºf air temp, and the motor run about 149ºf the higest was 167ºf with final top speed of 45.16 mph on 22.2v it is too speed???
For reduce weight and temperature because my lipos weight is 1.76lbs, And now I want to run it lipos http://www.hobbycity.com/hobbycity/s...idproduct=9268
Are enough? with less weight I will have less temp?
scarletboa 06.13.2009 03:02 PM
i would just gear down a tooth or two on the pinion gear. that should lower your motor temp a little.
jalodo56 06.13.2009 03:30 PM
are turnigy 2650mha 30c enough?
regards
Raze ST Truggy 06.13.2009 03:53 PM
I recently ran a Raze Buggy on 2 x 4S 2650 30C Flightmax packs in parralel for 5300mAh @ 30C with good results.
-Brian
jalodo56 06.13.2009 04:17 PM
-Brian
OK but I want to run only one lipo 6s 2630mha 30c, is enough?
speedracer1129 06.13.2009 09:55 PM
Nice buggy.
magman 06.13.2009 10:02 PM
That depends on how long your run time needs to be....The set up will work
jalodo56 06.14.2009 05:25 AM
I have just buy 4 lipos trunigy 3s 4000mha 20c for run on series....And a MicroPower V3 E-Logger but I don't know how to put it in my car, because my car have wires for conect the batteries in serie........
