-   -   15c High 4000+ mAh Lipo Usage (https://www.rc-monster.com/forum/showthread.php?t=21564)
Mentat 06.13.2009 09:25 AM
I was just curious if its at all possible to use 15c Lipos with the CC Monster Mamba 2200kv combo with any kind of luck? I wanted to maybe try in my 8ight-t 1.0 race roller. i was thinking maybe 4-6 cell lipo with 4000 - 8000 mAh. what would happen? would it be decent for just bashing around?
Thanks
Finnster 06.13.2009 10:04 AM
4s2p yes. 1P... not so good
Bondonutz 06.13.2009 11:04 AM
I tried a 15C 4s in my Lightning Stadium Pro conversion, It worked great for about 7-8minutes. Started to get hot and swell big time.
Recomend 20-25c+ to be safe and keep your investment,but more the better !
Metallover 06.13.2009 11:17 AM
I say 25-30c. You could fry your esc from insufficient lipos. I personally rock the 30's. :yipi:
suicideneil 06.13.2009 12:36 PM
15c x 4000mah = 60amps, no good.
Using a pair of packs in parallel would be fine (120amps), but then size/weight may be an issue for you.
