mm thermaling mm = bad thing or built in and safe
does thermaling hurt a mm or is it safe to buy a used thermaled mm that still seems to work fine?
lol can i edit my title |
Thermaling is done via measuring temps and shutting off the output, so it is designed for it, but it's a safety device so shouldn't be run that much constantly. Running things that hot often will shorten the life span. If it happened just once or twice, no biggie. Also, if it was run that hot, was it being otherwise pushed beyond its spec?
I've done some testing out of curiosity with an old MM.... I thermalled it repeatedly and eventually the system got so hot that one or two 13 ga. wires desoldered themselves from the board and promptly ended my test. However, if the MM was allowed to cool after the first instance of thermalling, there's no reason to worry about it's viability.
go stress test, that is good to know, thanks
| All times are GMT -4. The time now is 05:11 PM. |
