-   -   bullet connectors (https://www.rc-monster.com/forum/showthread.php?t=21586)
Mentat 06.14.2009 04:05 AM
bullet connectors
Hi, i just purchased a CC Monster Mamba Combo 2200kv and several Lipo packs. My question is this: Is it better to use deans connectors on the battery ends or can i use these bullet connectors? i like the look of the bullet connectors and would rather use them, but i do not know if they are able to be used on the end of the battery. I am new to Brushless setups. Anyone have any pics of a Bullet Connector only setup? I am not a 100% on how the battery connects to the ESC , i know that i am going to have to put some KIND of connector on my new LIPO packs, just cant decide on what and how Thanks
Mentat 06.14.2009 04:48 AM
Well , I went ahead and purchased some of these for my 8ight-t Monster Mamba 2200kv combo: 6.5mm High Current Bullet Connectors from Castle Creations, Hope these will get the job done.
http://www2.gpmd.com/imagel/c/lcsem0003.jpg
Unsullied_Spy 06.14.2009 06:03 AM
Those will handle it quite well, but make sure you put shrinkwrap over the connectors and make SURE you never plug them in wrong or you will short out your Monster and it'll be toast.
Patrick 06.14.2009 08:10 AM
And put the female plugs on the pack, so there's not much chance of them touching and shorting the battery, like they would if you put the male plugs on the pack.
zeropointbug 06.14.2009 09:58 AM
Yeah, you don't want the males to have a sword fight and kill the battery, so be smart and be a pussy..... use the female connectors on battery, as ANY power source should use female types.
brushlessboy16 06.14.2009 10:12 AM
I would go with a Keyed connector-you wont have to worry about plugging them in wrong or shorting- deans, trx and ec5 are all great..
Gee 06.14.2009 10:25 AM
Yeah, a keyed connection is the way to go. Even though you connect up the battey every time with great attention to detial for the last year. There is that one time that you are distracted, in a hurry, and not paying attention. Keyed doesn't let that happen.
Rebelgium 06.14.2009 12:37 PM
But the 6,5 bullets, (or 6mm bullets from HC) have less resistance than any keyed connector.
Less resistance= less heat and loss of power...
trev3813 06.14.2009 01:14 PM
Aren't ec5's just bullets in a casing? I think they'd be the best choice.
brushlessboy16 06.14.2009 01:18 PM
yes, but they are a keyed casing to prevent reversed polarity
trev3813 06.14.2009 04:43 PM
Well, yeah. So isn't it easier to just get those? :yes:
Rebelgium 06.14.2009 05:12 PM
yes, ec5's have bullets in them, but they're "only" 4mm bullets.
So 6mm or 6,5mm bullets still have significantly better current capacity.
I only recommend these bullets to high end MT or heavy set ups. You'll probably never notice a difference in a slash for example...
BrushlessReady 06.14.2009 05:14 PM
i use one male and one female connector on my esc that way i can't get them messed up
speedracer1129 06.14.2009 11:17 PM
That is a BAD idea!! I have seen many people plug the battery into itself because of that. Females are always on the power source!!
Unsullied_Spy 06.15.2009 01:42 AM
I wouldn't worry about the resistance in Deans connectors. I run them in a ~16 pound Muggy with an 80mm Medusa and haven't had a problem with them heating up, and I punish that truck pretty hard.
