-   -   Need help for converting Losi8T to EP (https://www.rc-monster.com/forum/showthread.php?t=21592)
superek4 06.14.2009 11:51 AM
need help here, i m building my friend's Losi8T to EP but while converting the spur to plastic 46T i realised the screws dun fit.
The orginal screws is CS but the plastic spur is not CS, what kind of screws should i use?
Do i really need to change the spur? can I still use the 48spur? Thxs!
bdebde 06.14.2009 01:00 PM
The steel spur will work fine as long as you have a hardened pinion.
JThiessen 06.14.2009 01:02 PM
WHen you say CS, do you mean counter sunk flat head screws? If so, just switch them to button heads.
nitrostarter 06.14.2009 02:40 PM
Yep, button head screws the same size should fix it.
superek4 06.15.2009 09:49 AM
Yes it counter sunk, ok great I will use round buttons thx guys
