-   -   LST 2-speed problem (https://www.rc-monster.com/forum/showthread.php?t=21616)
Byte 06.15.2009 12:48 PM
LST 2-speed problem
I've got a strange problem with my LST. It has got a 2-speed. But the problem is that it can only run backwards. If I turn the large spur (1st gear) one way, the car does move backwards, if I move the spur to the other way it doesn't move at all? And if I turn the small spur (2nd gear) it does nothing to, doesn't matter if I turn it to the right or left. (But that is right, isn't it?)
Does anybody know what I did wrong? (I completely disassembled the LST, and re-assembled it)
Thanks,
Patrick
nitrostarter 06.15.2009 12:54 PM
Sounds like you may have flipped the differentials around....
Metallover 06.15.2009 01:22 PM
Yeah
Byte 06.15.2009 01:33 PM
Oh crap.. Well, I think you're right, because on the Diffs stands "TOP" but I didn't get how to put them in that way, and so I putted them with the TOP pointed to the ground, and they fitted perfectly! :lol: So I did it like that...
Anyway, thank you both of you for your help! Now I only have to figure out how they should fit...
lincpimp 06.15.2009 04:01 PM
turn the diffs over, that will cure the issue.
