which medusa motor?
hello.
iam almost finishing my rc8 conversion and i need a motor for this car. i have a 150a hobbywing esc and i want a medusa motor for 4 to 6s, but mainly to run 4s lipo and to run cool at these voltage... which medusa should i choose? regards |
60mm 2000kv 4s to 1600kv 6s
and can they handle bigger gearing without getting too much hot? regards |
The 6s set up....Arct1K mentioned above is the more efficient set-up and will run cooler
If you want a 4s setup... but want to run 6s to goof off, you could do the 2000kv. Several local guys are racing this motor on 4s.
Too bad they don't have an 1800... that would be even better |
| All times are GMT -4. The time now is 03:11 AM. |
