-   -   Mamba max heat problem (https://www.rc-monster.com/forum/showthread.php?t=21708)
brushlessboy16 06.19.2009 07:40 PM
THe mamba max in my rc10b4 is temping at 175 at the end of a 10minute run, the setup is:
rc10b4
Feigao 7s (5070kv)
21/86
2s lipo
start power high
timing (0)
no punch control or anything else.
I took some time to cut the air vents in my proline vortex body for some more cooling along with the front windshield.
It was originally geared 24/78 which i found to be really high, changed the pinion and spur to the current gearing, and the problem persists. The motor temp is 145 after a run and the batteries are at 95. what am I missing?
If I could wedge my MMM into the car I would.
BL_RV0 06.19.2009 07:59 PM
Try lowering the start power
e-mike 06.19.2009 08:10 PM
also lowering the timing and add punch could help
and i think you overgeared no?
brushlessboy16 06.19.2009 08:19 PM
Been checking and rechecking the speed calculator- im geared for about 35mph with tire ballooning
timing is at 0 and punch is at zero, ill try start power and see what happens
Metallover 06.19.2009 09:10 PM
Maybe the motor is on it's last leg.. :sleep:
brushlessboy16 06.19.2009 09:39 PM
I doubt it, that thing runs like a bandit, perfect torque curve for the little car.
