-   -   40mm 12V Cooling Fan (https://www.rc-monster.com/forum/showthread.php?t=21748)
phatmonk 06.21.2009 08:36 PM
Will a 12V DC 40mm cooling fan run off my extra receiver plug to cool my motor?Its over 90 here in the midwest.
BrianG 06.21.2009 09:24 PM
If it does run, it will run very slow. If running 3s or 4s, hook the fan directly to the battery. If running over 4s, you can use a linear regulator to bring down the voltage: http://rc-monster.com/forum/showthread.php?t=5377
_paralyzed_ 06.21.2009 10:55 PM
or get a 6 volt fan that will plug into the receiver.
Patrick 06.22.2009 06:55 AM
I just run my 12v fans straight off the batteries. They spin pretty quick on 6s, but it hasn't killed them. Most of the time I use 4s though, so I don't know how long they would last if I was only ever using 6s.
blueb8llz 06.22.2009 01:59 PM
yup, i use 40mm 12 fans on 4s straight wired to the battery...spins very powerful. and hasnt died yet. its good to know that it will work on 6s too, because i may want to rig a fan onto that truck as well.
brushlessboy16 06.22.2009 04:22 PM
I have ran 40mm fans off 5s and 6s without failure, they are pretty beefy units, as stated- run it off the main battery and you will be fine.
blueb8llz 06.22.2009 07:48 PM
where do you guys get your fans from. i got mine from ebay. 3 fans for $5 shipped. unfortatly they dont sell them for that cheap anymore. now theyre like 3 bucks apiece!
brushlessboy16 06.22.2009 08:21 PM
i got mine from my school's robotics team, freebies :)
