Inferno GT 4s. What is the best setup to go to 60 mph ?
Hi,
I want to convert my inferno gt with a good setup, about 60 mph, with a good runtime (greater than 15 minutes). Suggestions? |
I'd say CC 2650 and 6000+mah bats should do it..
1 speed setup: Differential Ratio: 3.3076923076923075 Transmission Ratio: 1 Other Ratio: 1 Spur Tooth Count: 46 Pinion Tooth Count: 15 Total Voltage: 14.8 Motor KV: 4500 Tire Diameter (inches): 3.54 Tire Ballooning (inches): 0 Motor Current Draw: 0 Motor coil Ω: 0 Spur/Pinion Ratio: 3.07 : 1 Total Ratio: 10.14359 : 1 Tire Circumference (inches): 11.12 inches (282.48 mm) Total Motor Speed: 66600 RPM Vehicle Speed: 69.15 mph (111.07 km/h) Effective KV Value: 4500 KT constant: 0.3 oz-in/A 2 speed setup: Differential Ratio: 3.3076923076923075 Transmission Ratio: 1 Other Ratio: 1 ----1 gear Spur Tooth Count: 46 Pinion Tooth Count: 15 Spur/Pinion Ratio: 3.06: 1 Total Ratio: 10.14 : 1 ----2 gear Spur Tooth Count: 40 Pinion Tooth Count: 21 Spur/Pinion Ratio: 1.9 : 1 Total Ratio: 6.30037 : 1 Total Voltage: 14.8 Motor KV: 2600 Tire Diameter (inches): 3.54 Tire Ballooning (inches): 0 Motor Current Draw: 0 Motor coil O: 0 Tire Circumference (inches): 11.12 inches (282.48 mm) Total Motor Speed: 38480 RPM Vehicle Speed: 64.32 mph (103.32 km/h) Effective KV Value: 2600 KT constant: 0.52 oz-in/A |
Here's my setup.. 60+MPH and about 15+ minutes easy.
6S1P PolyQuest XP 25C 3700mAH, 1400 KV motor, MMM ESC, 46T Spur, 22T Pinion. |
| All times are GMT -4. The time now is 05:19 AM. |
