Revo Hybrid Diff Case/v3 bearing size?
Hello,
i search for the info long time. What size are the ball bearings for the input shaft at the new case? I need this info :) My aluminium cases has 12x6mm bearings - too small i think. Thank you Titan |
I believe they are 12x8 but not 100% sure
Thanks.
Somebody know it 100%? It is money so need to know it. :D Titan PS Is it the wrong forum? :) |
Looking at the pic of the different parts of the Hybrid Diffs, it really looks like the input shaft is 8 mm with the tip machined to accept the Revo shaft. I'm sorry I can't be 100% sure but it really looks like you need a 12X8 bearing like magman said.
Mhh but what change on V2 and V3? I wrote mike a mail, but no answer.
Titan :/ |
I can tell u the size but I'd have to open up my diff first..12x8 sounds right though
Mhh Okay, so i order only some 12x8er Ball bearings and replace them often.
Thank you. Nothing chances on case - so i can use the old one. Titan |
| All times are GMT -4. The time now is 12:16 PM. |
