Dual BL?
Hi Everyone!!!
Just curious to know why when changing from 2 brushed motors to brushless system, the norm is to use only one? Is it because only one is enough? Is it because there is no speed control for 2 motors and will need two speed controllers? Thanks:017: |
Its simply because brushless puts out alot more rpm and torque than a brushed application, daul bl is just a waste of time and money, if you want more info on daul bl , ask johnnymaxxima hes got a emaxx with daul 9L's .
One bigger brushless motor will out do a dual brushless set up. One good brushless will destroy the drive train in a stock maxx.
itl destroy more than that ;)
Yes duall brushless is a waste of money. I just did it because I could. Kind of a show truck I guess. It is too heavy to bash with also. A single brushless is usually plenty enough and way out performs the stock titans. Although my duall setup goes about 12mph faster than my single BL.
couldnt gear up a bit due to it being dual? i did that with my dual HV setup geared a little higher than stock form in my emaxx. |
Hey Johnnymaxxima what is your set up? Dual speed controllers?How many cells?
Thanks:017: |
use the search, please Psycho. it's mentioned lots of times before.
Thanks serum!!!:017:
| All times are GMT -4. The time now is 02:46 PM. |
