-   -   converting my gt2.questions (https://www.rc-monster.com/forum/showthread.php?t=21851)
cornolio 06.25.2009 03:58 AM
hi guys,im planning to convert my inferno gt2 to brushless.ive tried searching but never really got the answers i needed.
i want it to be single speed,~60mph using MMM 220kv combo on 4s.is it possible?do i need to get a kyosho buggy center diff?what else do i need to get aside from rcm motor mount,batt tray?
thanks in advance
streethot 06.25.2009 09:32 AM
I have done a GT Ferrari conversion
See what i have used
MGM / FEIGAO 7XL / 6S 5000MAH
MGM / FEIGAO 8XL / 6S 5000MAH
MGM / NEU 1515 1650KV / 6S 5000MAH
MMM / NEU 1515 1650KV / 6S 5000MAH
MMM / NEU 1527 1D / 6S 5000MAH
The best setup was MGM / NEU 1515 1650KV / 6S 5000MAH
with the MMM i would lost ABS and traction control, in that case isnt a good thing but still very good....
and for the experience with the GT car, a good low Kv motor is perfect < 2000kv......
my next buy to make speed runs with gt cars will be a 1521 1Y motor.....
SV6000 06.25.2009 09:42 AM
Hi Cornolio i have converted a IGT and used the 2200kv MMM setup on 6s. For a single speed i purchased kyosho center diff off ebay. You will need to run a longer shaft in the rear as the two speed is longer than the single. However there is an rc-monster adapter that you can buy with gears to let you complete a two speed electric conversion, as well as a plate that replaces the servo plate which will allow you use the brake servo to run mechanical brake. Do a search on forums for Kyosho Inferno GT conversions as Joe Ford from Castle creations has done a very good one and posted it here as well as on rccars.com. It has step by step pictures and all the conversion parts are from RC-Monster.
cornolio 06.25.2009 02:47 PM
thanks for the replies
which would be a more reliable setup,center diff or 2 speed?if i use the 2speed,how should i gear it(pinon,spur)?
