-   Slipperential discussion (https://www.rc-monster.com/forum/forumdisplay.php?f=45)
-   -   Slipperential Slipper Pads (https://www.rc-monster.com/forum/showthread.php?t=21853)
E-Traxxer 06.25.2009 04:24 AM
Hello! I just received my slipperential in the mail today and started assembling it but I have found that 1 out of the 3 slipper pads is too large to fit into the allotted space on the spur. It's fine if I grind/sand it down to fit, right?
Thanks!
Also, amazing little piece of machinery, seems like you did a great job on it so far.
Arct1k 06.25.2009 06:24 AM
Just flip it over /try it in a different slot - I had the same but it does actually fit...
E-Traxxer 06.25.2009 07:53 PM
The 1 piece still won't fit, it's a good 1.5mm wider on one end than the other.
Arct1k 06.25.2009 08:37 PM
I had that but it squeezed in - Hit it with the dremel
E-Traxxer 06.25.2009 08:57 PM
Will do!
What's_nitro? 06.25.2009 10:34 PM
Also make sure there isn't any slag left in the spur from the hardening process. There was some in mine and the slipper pad wouldn't sit flat in the gear. This causes it to wobble.
