-   -   Sidewinder Micro ESC (https://www.rc-monster.com/forum/showthread.php?t=21877)
BashemSmashem 06.26.2009 11:21 AM
Hello , I have a mini REVO and I was wondering how many amps the Sidewinder micro can handle as I want too put it in my truck . Some other people have tested the stock VXL system and they were getting peaks of over 50 amps .
Pdelcast 06.26.2009 11:41 AM
The Sidewinder micro can handle about 30A continuous, and peaks of about 50-60A.
BashemSmashem 06.26.2009 11:54 AM
Hmm, looks like I will have too give it a shot then !
BrianG 06.26.2009 11:58 AM
Bashem, what battery chemistry and voltage were those peaks recorded at? Using equivalent voltage quality lipos will probably cause current to peak a bit higher since there will be a little less voltage drop than NiMHs.
e-mike 06.26.2009 11:59 AM
i will no afraid to put this little beast in the mini revo just gear it suitably:yes:
Arct1k 06.26.2009 12:29 PM
Personally I'd use a regular S/W...
e-mike 06.26.2009 12:32 PM
me too its shoold be more safe and not a lot expencive..
Unsullied_Spy 06.26.2009 12:36 PM
The Mamba Max is compact enough to fit nicely. I imagine the MM would be enough to push the mini to 100 or so :tongue: The Micro Pro or 1/10th SideWinder would be great alternatives to the stock ESC IMO.
BashemSmashem 06.26.2009 05:06 PM
Well I had the Sidewinder micro sitting around and I wanted to see if it could handle 3s in the mini REVO with the stock gearing , I did run it and it was better than the stocker BUT it did hit the thermal cutoff on 3s so I might have to look elsewhere ....
BL_RV0 06.26.2009 05:14 PM
1/10 SW is good
BashemSmashem 06.26.2009 05:19 PM
Kinda big though , I am thinking maybe a Mamba Pro when they are released , that pic that shows it next too a quarter is sweet , nice and small and will take the power ...
Pdelcast 06.26.2009 05:21 PM
That was only the control board -- the full Mamba Pro ESC is about the same size as the Mamba Max.
BashemSmashem 06.26.2009 05:23 PM
Oh , bummer , still small but if you could fit it all onto that one board that would be freaky !
skellyo 06.26.2009 07:05 PM
I'm about to do just that. My Sidewinder should be here tomorrow or Monday. It shouldn't even break a sweat on the 380 motor in there...until I bypass the internal BEC and run it on 4S for a few speed runs. :intello:
BP-Revo 06.27.2009 07:04 PM
I currently have a Mamba Max in my 1/16 E-Revo with a 1112 Neu.
Have yet to run it, need to do a few more things. I'll get pictures up when it is done though.
