-   -   Parallel adapter (https://www.rc-monster.com/forum/showthread.php?t=21886)
bcltoys 06.26.2009 08:11 PM
Parallel adapter
Can a parallel adapter be found made with 6.5 bullets.Or do i have to make my self.
suicideneil 06.26.2009 08:23 PM
Nay, DIY item. I wouldnt trust a shop bought item myself, had some cold solder joints on battery charger leads so its better to do it your self, that way you get the exact length you need too. :)
bcltoys 06.26.2009 08:46 PM
Okay so i makey my self,what size wire should i use.
suicideneil 06.26.2009 09:38 PM
10g, given the size of the plugs and wires on the MMM. Use good quality lead-free solder too, or silver solder.
whitrzac 06.27.2009 12:34 AM
well, if lead causes cancer in other stats besides CA, I'm screwed:drunk:
Jabe 06.27.2009 05:30 AM
Do it like this, there is no wires to resist.
http://i92.photobucket.com/albums/l1...h_IMG_2769.jpg
Those plugs had through holes, where i put pure copper rod and then soldered.
Thomas 06.27.2009 04:55 PM
Excellent idea. How do you insulate this connector?
suicideneil 06.27.2009 05:03 PM
1 Attachment(s)
I would use either electrical tape, or plasti-dip and brush it on.
Heres my effort, basically the same thing only with 5.5mm plugs:
bcltoys 06.28.2009 08:57 AM
Where can you find 10 gauge wire i can find 12.
magman 06.28.2009 10:08 AM
Nicely done...may have to use this idea in the near future
suicideneil 06.29.2009 08:01 AM
12g is alot more common and perfectly fine, but given the size of the plugs its probably better to use wire the same size as such:
http://www.amainhobbies.com/product_...e-30-Red-Black
http://www.cheapbatterypacks.com/?sid=1628787&pgid=wire
http://www.hobbycity.com/hobbycity/s..._Soft__(1mtr)_
bcltoys 06.29.2009 06:59 PM
Thank you Mr Neil.
