-   -   Help with CRT part #'s (https://www.rc-monster.com/forum/showthread.php?t=22042)
Kyosho 07.03.2009 11:46 AM
I cant seem to find the center drive shafts for the x1 crt. if someone has the part number that would be very helpful. and also what do i need to change from 43/13 diff ratios to 43/10? do i just need the pinion?
Thanks
riverat1540 07.03.2009 01:45 PM
to do the ring and pinion conversion u need the ring and pinions from a hotbodies lightning stadium, and the center shafts part number is 40695 they are the same front and rear, also u will have to do some shimming to get the right mesh on the ring and pinions as the hot bodies pinions are a bit larger in length. hope this helps.
Kyosho 07.03.2009 01:59 PM
my center shafts are different, the front is shorter than the back.
thanks!
