4 or 5lipos ?
Hi !
I have an ass rc8e ands a cc-mmm 2200kv combo that i'm going to race with :O) but i don't know if i chould use 4 or 5s lipo's ? What do you guy's think ? |
Either will work, but for a given speed, 5s will be gentler on the batteries and runtime will be longer. So, whatever speed you gear for on 4s, gear down for 5s to get the same speed.
i use both, if i have to make a little longer race i throw a 5s pack in there, since there is more total energy in the pack
I prefer to race with 5s liking the speed and power that I get from 5s.
use the calculator on BrianG's signature to see what speeds you will get with either battery and what gearing you'll need to run for that speed. Sometimes the higher voltage won't let you gear down enough for usable speeds on the race track.
No, no, no, don't go 5s. There are a few good reasons why 4s is better in your situation. For one, the amount of power available is way, way to much for any type of track. You don't want something that is comfortable for 50-60 mph when you are spending most of the time going less than 30 mph. With the low throttle that you will be using most of the time, you will be heating up the esc a lot. Even if you geared way down, the motor will be spinning for nothing, and eat up your packs in a hurry. Reason 3 is the fact that 5s is taller than 4s. You want the lowest center of gravity for the best handling.
4s would be better for racing. Just get some good batts, like 30C and 5500mah or more of capacity and you should be good.
i dont race.... i bash, but my friends that race all prefer 4s
I forgot to say that i race on a grasstrack !!! Does that change anything ?
Grass pull more amp's right ? and what about 15/46 gearing ? |
i want to chime in here. I have an 8ight-t 1.0 converted to Electric using CC Monster Mamba 2200kv combo and i have both 4s and 5s. 4s is way better on the track. Its the only time i run the car is on the track. Im getting 25mins outta my 4s 5000mAh 20c/25c packs. I get about the same on the 5s. 4s +++++ 5s is way hot, but runnable. 48t/15t gearing with the 4s packs no prbs
4s is more than necessary.
5s, maybe for a big track with higher speeds and longer straights. Turning down the EPA is non-sense. Set the car up right. Turning down the EPA is limit the ESC and thus making it always have to work hard to know the motor timing and when to send power. Where as, when you have the ability, the ESc is now capable of working less, or "thinking" less and should therefore run cooler. |
I still think that 5s geared down a little would be a better choice for bashing, especially on a grass track. And if he wants to gear up a little for some speed runs, it will be more than ready.
Couldn't agree more for bashing. For racing, 4s is plenty and even sheds a little weight from the lighter 4s pack. Lighter= less strain. But I also have to fall back on Steve Neu's recommendations of his motors being design to be most efficient in the 30-35K rpm range. |
Yes, for racing, I agree; 4s. But he did say he's racing on a grass track. :wink:
| All times are GMT -4. The time now is 05:39 AM. |
