-   -   What speed controller to use???? (https://www.rc-monster.com/forum/showthread.php?t=22081)
SV6000 07.05.2009 04:57 AM
Hi guys i have a G3R CF build that is in desperate need of a new speed controller as the MGM i had on it has just bit the dust:grrrrrr::grrrrrr: for the second time.
I am running a 1521 1Y and would like to run 6-8s. I have already tried the MMM and it doesn't have enough in it for prolonged 6s use.
So what contorller do you guys think i should use.
Electric Eel 07.05.2009 06:03 AM
If the MMM can't cut it, try Castle's Hydra HV240. Even without water cooling it should handle what you want. Just talked to a guy running one in a Baja 5T with a Neu 2215 motor. He says it doesn't even get hot. Expensive though.
SV6000 07.05.2009 07:41 AM
I have thought about that but i cant run a mecanical brake, so that puts it out of the hydra out of the question
pinkpanda3310 07.05.2009 08:23 AM
You'll be hard up finding an esc that can handle the braking then
bdebde 07.05.2009 12:25 PM
What MGM where you using? If it was an older model, perhaps one of the newer ones (with higher current rating) would be a good replacement.
SV6000 07.07.2009 12:17 AM
I was using the 280A Zseries model. It is the second time this speed controller has failed and to tell you the truth i am getting a little sick of it. I saw the recordings from the black box and the highest amp draw was just under 75A. I would like to run a hydra but i would have to make a custom chassis for that. There isnt really a lot of room to mount a brake servo and brakes on a gorillamaxx G3R chassis
suicideneil 07.07.2009 11:19 AM
Something from Kontronic perhaps? The newer Jive models have brakes but no reverse I think, and pretty decent current ratings, along with something like 8s to 12s capability depending on the specific model.
nitrostarter 07.07.2009 11:21 AM
Give Lutach a buzz and see if he has any 10s controlers left.
aqwut 07.07.2009 12:27 PM
I was curious of how the hydra would handle, so I got myself 2 of the HydraHV 240 and 2 of the Hydra 240... If you get yours before mine, let use know how it works for Land vehicles..
nitrostarter 07.07.2009 01:13 PM
Nice $1000+ dollars on 4 esc's...
fine Design was using them in his 1/5 scale conversion.... lol
BL_RV0 07.07.2009 01:15 PM
Hey Cory! It's aqwut man!!!!
SV6000 07.08.2009 09:33 AM
Hey guys here is a development. Due to an ordering mix up and a supplier not listening:slap: i have ended up with two yes 2 Schulze 24-150WK speed controllers. I guess i will run one of them on this truck:grrrrrr:
_paralyzed_ 07.08.2009 10:13 AM
oh man, those firecrackers would have been great on the 4th!:lol:
nitrostarter 07.08.2009 11:07 AM
Yep, you have to watch those may-pop's and their setups...
